| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 66 | Just finished putting the motor together filled it with oil pumped it up with a drill I noticed the next day that oil was leaking thinking it was a rear main seal I pulled the pan and it seems to be the rear pan gasket leaking. I don't think oil gets that high to hit the rear seal. Any ideas? Also I had put in a neoprene rear seal in the block which is an early 1954 should I replace it with the rope while I have the pan down. | | |
