4 members (Donf, msmall, 2 invisible),
120
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I have a rebuilt 235 and I am currently running an 11" (10 and something") clutch and 9 bolt pressure plate with a T5. My question is do I need to run this size or is this overkill. I have smaller size flywheel PP combos so I'm just curious what size I really need when I go get a new clutch plate to match the 26 spline T5. I don't hotrod just go to parts stores etc.
Rick....... | | | | | Joined: Mar 2014 Posts: 4,511 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,511 | 10 3/4" is what I think you have. It should be fine. Anything 10" or larger should be ok. Based on what I've been told by clutch guys (guys who do this for a living, that is), just stay clear of the 9" disk. Apparently they don't last long and have other problems. I'm going to be using an 11" disk, pressure plate and flywheel on the 1959 235 behind which I'll be running a T5 NWC (Astro Van) transmission, by the way. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
