5 members (UtahYork, Gray_Ghost, klhansen, mason86, Charles in CA), 95 guests, and 2 robots.
Topics128,069
Posts1,055,884
Members48,428
#110852 10/26/2003 6:48 AM
Apprentice
Apprentice
I'm starting to put my 57 back together. I would like to use stainless steal fasterens. Is there anything I need to do to them in order to paint them?
#110853 10/26/2003 12:14 PM
Welcome to the Stovebolt Rick57 cool
One thing I can say about stainless bolts is that they can work loose real easy as the hardness of the stainless does not allow the metals to grip each other as plain steel would.
You would need to either use some good loc-tite when assembling the stainless nuts and bolts or use some type of self-locking nuts with the stainless bolts.
As for painting them,,,, why not polish them grin
#110854 10/26/2003 1:34 PM
Rick57: Luke is right you got to LOCTITE them or locknut, just wondering tho if your useing SS why paint them? popcorn The Truth is Out There (SS is pretty and cool just my thought)
#110855 10/26/2003 3:28 PM
Paint does stick to well-preped plated steel fasteners better. I use Nylok nuts with stainless scews and bolts.
#110856 10/26/2003 11:08 PM
On the SS hardware I used that were painted, like bumper bolts, I had the advantage of a bead blaster at work. Just lightly hit them to rough up the surface and so far so good. When assembling I used flat and lock washers with the nylock nuts also in SS. I just blasted the heads or whatever would be taking paint and left the rest as is.
Bruce
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
#110857 10/27/2003 3:30 AM
Apprentice
Apprentice
Thanks for the imfo.
#110858 10/28/2003 5:14 PM
Quote
Originally posted by Norselander:
You are likely to have "thread galling" when using "stainless on stainless." An anti-seize agent will help prevent galling.
Loctite or Vibratite will also prevent galling.
Be careful about the bolts you buy. I learned the hard way. Found either improper or no heat treat on the bolts I bought through American Clasics. The bolts at the hardware store aren't any better. I would recommend getting bolts from either Totally Stainless or GMC Pauls . I know they both sell quality bolts.
Fred
52 3600
69 C-10
