1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I have a little rust spot to fix | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | If you follow the lead of the previous owner of my truck, all you need is a little under one gallon of bondo, a quart of resin and sloppily applied loose fiberglass. Carl
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Or maybe duct tape it then fill the inside of the cab corners with foam insulation. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I've recently seen hvac duct work taped in with hvac tape. Looked like a crocodile cut the pattern, too... If'n you want to fix it right, I was recently talked through how to fix my rear fenders here in this Paint/Body forum. I think I made all the mistakes possible (only so others could read along & do their patchwork correct the first time.) You've got some nice trucks, though. That's one interesting bumper as well. Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Thanks Brad. I have the bumper off now and I cut those big square chunks of iron off. I'm working on the rust now. I'm getting better with the wire feed so now I don't have to do as much grinding. The hole in the cab corner is bigger than the LMC patch so I have to make up the difference with sheet metal. I think this will be my last truck. I'm getting so I enjoy driving them more than working on them. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I used a piece of a correct-gauge electrical box/fixture for the 3" tall, 6" long portion the vendor patches did not cover on one of my corners. Brad Wrench Fetcher, PhD | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I've used computer cases as well. Whatever works...
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Until you use your wife's favorite cookie sheet. Thats when you might as well just go and kill yourself.  | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I didn't want to mess with the teflon non stick crap... too much work
| | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | I have an old file cabinet. I'll bet that will work. | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Deve--, if I did that I likely wouldn't need to take care of it myself.  | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | |
