0 members (), 160 guests, and 5 robots.
Topics128,149
Posts1,056,818
Members48,456
#110828 08/01/2004 3:43 AM
Junior Member
Junior Member
What wire and gas would you you use on a mig welder to french in your stainless hedlight rings to your steel fenders ?would regular steel wire and 75/25 argon work ? Thanks
Junior Member
Junior Member
use stainless wire. when welding two different materials together always go with the higher grade as the filler.In this case the stainless being the higher. something in the 300 series should be good. normally 308 is a good choice.as far as the gas I would think that your 75/25 should be ok.Good luck
