1 members (WingWright), 103 guests, and 1 robot.
Topics128,049
Posts1,055,680
#1108099 06/14/2015 2:14 AM
I have a little rust spot to fix
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
If you follow the lead of the previous owner of my truck, all you need is a little under one gallon of bondo, a quart of resin and sloppily applied loose fiberglass.
Carl
Or maybe duct tape it then fill the inside of the cab corners with foam insulation.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
U
U Offline
I've recently seen hvac duct work taped in with hvac tape. Looked like a crocodile cut the pattern, too...
If'n you want to fix it right, I was recently talked through how to fix my rear fenders here in this Paint/Body forum. I think I made all the mistakes possible (only so others could read along & do their patchwork correct the first time.) grin
You've got some nice trucks, though. That's one interesting bumper as well.
Brad
Wrench Fetcher, PhD
Thanks Brad. I have the bumper off now and I cut those big square chunks of iron off. I'm working on the rust now. I'm getting better with the wire feed so now I don't have to do as much grinding. The hole in the cab corner is bigger than the LMC patch so I have to make up the difference with sheet metal. I think this will be my last truck. I'm getting so I enjoy driving them more than working on them.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
U
U Offline
I used a piece of a correct-gauge electrical box/fixture for the 3" tall, 6" long portion the vendor patches did not cover on one of my corners.
Brad
Wrench Fetcher, PhD
I've used computer cases as well.
Whatever works...
Give me ambiguity
or give me something else
Bart #1108270 06/14/2015 11:57 PM
Gas Pumper
Gas Pumper
Until you use your wife's favorite cookie sheet. Thats when you might as well just go and kill yourself. wink
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I didn't want to mess with the teflon non stick crap... too much work laalaa
Give me ambiguity
I have an old file cabinet. I'll bet that will work.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Deve--, if I did that I likely wouldn't need to take care of it myself. dance
Gas Pumper
Gas Pumper
LOL!
Deve
The Think Tank
