4 members (PAUL Berardi, Simso, Gray_Ghost, JW51), 117 guests, and 1 robot.
Topics128,111
Posts1,056,244
Members48,437
#1108205 06/14/2015 4:16 PM
In electrical I asked about high charging at high rpms. I have noticed another issue. I was waiting in line for gas and noticed the trucks temp gauge going up so I shut it off. Then it wouldn't start until it cooled down. Do I have an issue and how can I chase it down? Are there steps I can follow?
Thank you
Dennis
ODSS President
ODSS President
I am interested in this thread as this issue happens to me frequently in warmer weather...starting again after a short term shut off, be it a 500 mile day or frequent yard sale stop/shut off/go in warmer weather. I have an alternator, do not have Dave's 'water pump re-locator' on this '56 engine but do have it installed on a '62 261 I am in the process of getting together for a summer install.
~ Cosmo
1949 Chevy Half Ton
Hi. Sorry to hear it but glad there's two of us. I do have the water pump re locator on my 235. It fits well and put the water pump in the right place. I am thinking of replacing my coolant to see if that helps. Not sure if a 50/50 mix or all coolant is best. Thanks
Dennis
ODSS President
ODSS President
~ Cosmo
1949 Chevy Half Ton
So your engine will not start.
It cranks over but not fires?
Have you checked the spark while it is cranking?
If that is good then sounds like a fuel problem related to heat.
If it cranks and if you have spark then splash a table spoon of fuel into the carb see it if runs for a few seconds.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
Ignition timing to retarded can cause overheating.
My Blog
Never run more than 70% concentration of antifreeze- - - -it needs at least 30% water to transfer heat properly, and pure Ethylene Glycol starts to freeze at +19 degrees F. A 50/50 mix freezes at -37 degrees F. and boils without pressure applied at about 220 degrees. If it gets colder (or hotter) than that in Tennessee, I'm moving to Tahiti!
You might be experiencing "hot soak" where the fuel in the float bowl boils and percolates into the intake, causing a flooded condition. Try holding the throttle wide open and cranking until the engine starts to clear the flood.
I'm going to agree with Jerry here. If you run your truck for half an hour or more (takes less on hot days), shut it off and restart it within five minutes, it'll be fine. If it sits longer, the heat under the hood from the hot engine causes Jerry's "hot soak". It will also cause the fuel in the fuel line from the pump to the carb to expand, feeding more fuel into the carb even after it's shut down. If you were to pop the hood you would find your carb is wet from excess fuel seeping out.
You can shine a light down through the carb and look for pooled up gas on the bottom of the intake manifold. More of the excess gas ends up there than what seeps out of the outside of the carb.
Carl
Well Dennis that will teach you to move from nice cool Texas to overly hot SoCal. I agree with Jerry, that is what we use to do back in the day. Hold it wide open and crank.
After a couple of generations of driving vehicles with fuel injection, we sort of forget how to deal with a flooded engine. I guess that's a good thing, "progress"- - - -until we try to deal with antique technology!
Still have not found the OBDII to plug my snap-on solus into.
But that is a good thing.
