2 members (Bill Hanlon, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Most of you know I have titanium rods in my back so I can't do very much lifting. So I had to figure out a way to do engine work anyway. Years ago I purchased this winch from Harbor Freight. Its an 880 pound capacity. http://www.harborfreight.com/880-lb-electric-hoist-with-remote-control-60347-9120.htmlAnyway, I have it very securely fastened to one of the main beams on my building so I am not in the least worried about it falling. I use this after getting a few guys to move the engine block to the floor (from the Explorer) then I can take it from there. Once the block is on the engine stand (piece of cake with this winch) I do the lower end of the engine, then before I put on the Head, I take it off the engine stand, and put it on the test stand with the same winch. This thing has paid for itself many times over. http://devestechnet.com/Images/Projects/Project1959235/Project59235321lg.jpg | | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | I set up the same winch in my shop last year. So far, only needed it to reset the cab on the frame of the '46 project. It worked just fine. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Cool tip Deve. I just hope that I have enough sense very soon to buy one before I need some titanium plates. Carl
| | | | | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | When I built the rotisserie for the 240Z I incorporated a small derrick in each one to use this winch to hoist the end of the body in the air to attach to the stands. Worked well.
I have used this winch for years to hoist parts up to the second floor of my garage. I built a small deck with swing out gates in front of the sliding patio doors and added a pretty beefy derrick that uses this winch. Very happy with it and the remote control is excellent.
I'm in the process of building a dock lifting system at the cottage that will use this winch as well to aid in the launching of them. | | |
