5 members (Otto Skorzeny, klhansen, 54farmtruck, J Lucas, Bill Hanlon), 110 guests, and 4 robots.
Topics128,151
Posts1,056,994
Members48,460
OK I should have known to read first but in and attempt to prep my 235 block for its visit to the machine shop I removed 1 of the round head bolt that holds the oil pump housing to the block. It some how seemed wrong so I took the time to read our FORUM topics to find out they should not be removed. Question...how do I put the round head bolt back or can I use a grade 8 or 9 bolt in it place.
I would grind six sides to the round head to except a socket.
It is important to use that shouldered bolt.
I would also use Loctite on it.
My Blog
Thanks Dave for a solution...it seems to be the only way to reuse the shoulder bolt.
Thanks again Dave...the shoulder bolt is back in place with Loctite and the block is now ready to transport to my machine shop.
I had a machine shop remove one of these in the past and had to do the same thing.
Glad it worked out for you!
My Blog
