| | | Forums66 Topics128,176 Posts1,057,121 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | OK I should have known to read first but in and attempt to prep my 235 block for its visit to the machine shop I removed 1 of the round head bolt that holds the oil pump housing to the block. It some how seemed wrong so I took the time to read our FORUM topics to find out they should not be removed. Question...how do I put the round head bolt back or can I use a grade 8 or 9 bolt in it place. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I would grind six sides to the round head to except a socket. It is important to use that shouldered bolt. I would also use Loctite on it.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | Thanks Dave for a solution...it seems to be the only way to reuse the shoulder bolt. | | | | | Joined: Jul 2013 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 46 | Thanks again Dave...the shoulder bolt is back in place with Loctite and the block is now ready to transport to my machine shop. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I had a machine shop remove one of these in the past and had to do the same thing. Glad it worked out for you!
