9 members (Hotrod Lincoln, 55shaker, MickeyP, 50Chevy3100, frogfarmer, Pre '68 Dave, 3 invisible), 107 guests, and 4 robots.
Topics128,260
Posts1,058,322
Members48,485
I am in the process of hotrodding my 46/7 pickup and I wuld like to use bucket seats. What are your suggestions for a donor for bucket seats. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
I have a '42 with the same idea. Can't wait to see some answers.
I used an S-10 bench and personally don't see the reason to put buckets in these small cabs. However, have you looked at s-10 buckets? The blazers had them and they would definitely fit.
My 46 GMC on Photobucket
We had buckets from a '70 Firebird in my son's '53. I would suspect most any will fit the earlier truck if you can fabricate the mounting brackets. The original brackets bolted to the floor will be way too low. Search the salvage yards for a pair that the color and fabric are to your liking and go for it.
P Online: Content
I believe I had Vega buckets in my 37 PU in high school.
My Blog
I agree with above on S10 bench. Cab is not that wide....thinking seat is about 54"? I bought a set of Caravan leather fronts(40bucks at garage sale) and removed frame and set in my 4t6. They almost touched with no room for a console and just didn't look right. I use them for garage seats currently so at least they're being used. Probably should have used the seatbelt as I almost fell out when snoozing....lol
Dan
Dan
I think the width is more like 46", of the seat itself.
I used a pair of Pont Fiero bucket seats and built a small counsel/arm rest in between in my 40. They also had the advantage of having the speakers in the headrest.
I used the buckets out of a 94-97 pontiac grand am. Fit good and price was right.
We scratch make our seats for the old narrow cars as most, but not all, modern seats just don't look and/or fit right. Attention to the seat riser and keeping the back low will make or break the out come. Pics show buckets in a 40 pickup and a bench in a 34 cabriolet. I like the bench but it's your truck so it's your choice.
http://s32.photobucket.com/user/coilover/media/StudeJustins40CougarCat004-1.jpg.html
http://s32.photobucket.com/user/coilover/media/DanZstwo34s001-1.jpg.html
Evan
Why buckets? Well if you are 6'2" and your wife wants to drive and she is 5' it's a no brainier.
1937 Chevy 1/2 ton panel
I moved the gas tank and used 88 Astro Van captain chairs including the base frame, four bolts.
I put a 2nd row chrysler minivan seat in my 46 1/2 ton fit perfectly just had to make mounts for it
