| | | Forums66 Topics128,035 Posts1,055,549 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 21 New Guy | | New Guy Joined: Jan 2009 Posts: 21 | I have got a 1949 GMC 3/4 ton with a 9 ft bed and it has the dual piston shock system on it and looking for a company to rebuild them for me! anyone have some information for me? | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Dan, Here is a shop that can rebuild yours. http://www.applehydraulics.com/shocks.htmKind of pricy though. Are your shocks locked up, or are the shaft seals just leaking? If the truck was driven much with dry shocks, the mainshaft may have been ruined rendering them unrebuildable. Hopefully the seal is good and you may be able to cycle the pistons several times and purge out the contaminants in the reservoir. Paul | | | | | Joined: Jan 2009 Posts: 21 New Guy | | New Guy Joined: Jan 2009 Posts: 21 | | | | | | Joined: Jun 2010 Posts: 170 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 170 | I sent two double acting shocks to Apple Hydraulics. The end price was actually lower than they had quoted me as less work was required. I'd definitely recommend them. | | |
