| | | Forums66 Topics128,139 Posts1,056,754 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | I'm stripping several 'checked' layers of old paint on a 70 C60 cab. Taking it down to metal. I've tried chemical strippers (messy and slow), scraping (hard work) and a disc sander with 80 grit. The disc works the best but man its still slow and messy. Plus, there's several areas I can't get into with the disc.
Am I just a sissy or, is there a better way? | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Hire some one with a dustless blaster system.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | To quote a certain Blues Brother. .. "whada ya want for nothin... rrrrruuubbbbbber bizkets?"
Welcome to the twilight zone. Those 3M stripping disks work great and a die grinder helps get the tight areas but in the end a sand blaster is mighty handy. What ever it is short of paying someone else it's gonna take some time. More time than you imagined...
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I use a Harbor Freight poly carbide disc on my grinder. It works FAST and strips right down to the metal but cannot get into corners or really tight areas. So it is not the final word. For me, I strip what I can with the disc because it's fast and cheap and my labor is free. The tight areas will need sandblasting. A few light passes over the already stripped metal will give it a good texture and reduces the heat that would be created by sandblasting alone. Check my signature and view recent posts on my BLOG. I recently stripped several panels.
| | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | When I stripped my pickup bed, I used a wire brush in my angle grinder. It worked OK, but trucks sure have a lot of surface area. Are the poly carbide disks faster?
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | When I stripped my pickup bed, I used a wire brush in my angle grinder. It worked OK, but trucks sure have a lot of surface area. Are the poly carbide disks faster? Yes
| | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I can strip 1 square foot of flat sheet metal in 2 minutes with a poly carbide disc. The disc is $4.99 (less if you use a 20% off coupon). I can probably strip 30 square feet (outer surface of hood and 2 fenders) with one disc. Watch the direction of the disc when you come up to an edge or you can ruin the disc. I'm using an electric 4.5" Makita angle grinder.
| | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | I can strip 1 square foot of flat sheet metal in 2 minutes with a poly carbide disc. The disc is $4.99 (less if you use a 20% off coupon). I can probably strip 30 square feet (outer surface of hood and 2 fenders) with one disc. Watch the direction of the disc when you come up to an edge or you can ruin the disc. I'm using an electric 4.5" Makita angle grinder. Wow! I'm going to have to get some of those disc. I'm now using the flap type disc, the one with multiple layers, and it takes me around an hour and a half to do the bulk of one door. Then there's the spots I cant get to... But, At that point I'm worn out. I believe a big part of the problem is the fact that there's so many layers of paint. I'm seeing at least four different colors. All that paint really loads up the disc. I keep it moving fast to keep the heat down and make multiple passes. I don't know of a mobile sandblaster in my area. I wonder whats the going rate to blast a cab down to bare metal? | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | With the HF poly carbide disc, be sure to wear a dust mask and dust will get everywhere. So do it outside. Try to keep the disc fairly parallel to the surface. It will last longer that way. Once you try it you will never go back to a flap disc for flat metal surfaces. Keep the disc moving so you don't build up heat. You can go back over heavily pitted area and remove a lot of the rust. Then go back over those pitted area with media blasting.
The disc will save you a lot of time. | | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | Can you give me the HF item number? I searched their site and don't see a "poly carbide" disc. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | The blue Norton Paint Stripper discs (Sears carries them) last longer than the HF ones, but both are better than anything else I have used. Carl
| | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | Thanks. The HF website could not find it when I searched there. | | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | +1 for the HF PC disc. I picked a couple up today as well as a new 4.5" grinder that was on sale for $15.
What little time I spent testing seemed to go pretty fast.
It took down an area about two feet sq to metal in about five minutes.
I'll get busy this weekend. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So then, you should be done with the cab by noon, since it's only about 100 sq.ft. and that amounts to a little over four hours. The hood fenders and grill by supper and that only leaves the bed for Sunday morning. Better get some primer for Sunday afternoon. Yep, sounds like a plan. dg
Denny G Sandwich, IL
| | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | I'll let you know how that goes Denny.
I'm afraid my 'duty cycle' may be a problem.
Dan | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | 3m Bristle brushes work great for paint removal, easy to control and flexible
they come in 1",2",3" & 4 1/2 cup they also have small bristle brushes for small areas | | | | | Joined: May 2015 Posts: 11,120 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,120 | I sure wish they had those polycarbide disks back when I restored my '29 Ford pickup in the 60's. I went thru sandpaper disks and wire wheels by the dozen. More than once the disk went whizzing over the hedge to the neighbors's yard.  I picked up a polycarbide disk at Lowe's, and MAN does that thing work nice  . I haven't used it much yet, but it's gonna get a workout on the '51.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 |
| | | | | Joined: Nov 2005 Posts: 116 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2005 Posts: 116 | The one I picked up was item number 60571. I notice they carry another one, # 94017 also. I don't see what the difference is.
I think I'll pick up some of each and see how they compare. | | |
