7 members (Ponchogl, frogfarmer, 2-Ton, Hanks custodian, Gdads51, Naturalthud, DoubleB),
236
0
Mod | | | Forums66 Topics128,081 Posts1,056,071 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | 55.2 Gmc 12 volt with a small block Trying to see if my temp and ampere gauge work or not. The ampere gauge has two poles. Temp gauge has one very unique pole. Here's a photo - https://flic.kr/p/uwde1BIs there a way I can bench test them? I have a multi meter but I'm a rookie with it. I do not know if the gauges were meant for a 12v or 6v system. And I bought a voltmeter today that I plan on installing in place of the ampere gauge, but I would like to at least see if it works.
1955 GMC 100 Series 2
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | The AMP meter is best tested safely with a variable current source or supply and variable load to adjust circuit current. If you have a fair understanding of electronics you can mock up a tester for this. A multimeter by itself will only check the shunt resistance in ohms. You may show vary low current from the shunt but the meter coil may be open.
Your temperature gauge should be a heated bulb sender. It is not an electric sender. From the shop manual -- The temperature indicator consist of an indicating unit in the instrument cluster, an ether filled bulb in the cylinder head and a small tube forming an air tight connection between the two units. As the water in the cylinder head warms up the ether expands causing then hand on the dash unit to move toward the right indicating the water temperature. -- Pressure on the fitting hole should show needle movement, but the unit will need a repair adding the bulb and tube.
OH, 12V system
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Yeah, I'm probably not going to be able to test the amp meter, that's over my skill level.
As to the temp gauge, it's from a small block 350, not the original engine in the truck.
| | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | Temp still looks to be a bulb and tube mechanical unit, not and electrical type.
I had not done this for years but in past had a quick "dirty" check on the amp meter using a standard cheap 9v carbon battery (disposable). New out of package these provide about 5 amps of short circuit current. You apply the 9V terminals to the amp meter terminals direct for a second or two and should read about 1/6 - 1/4 of the scale for a 35amp meter. Then flip the battery and read the other direction.
Again a second or two at most to keep overheating the battery to minimal. The battery life will be sucked out of it so get cheapest battery you can find. No rechargeable battery types as short circuit is no good for them.
If you still have a radio shack go and buy model 270-324 catalog #2700324 Heavy-Duty 9V Snap Connector. for battery a HF 9V battery item#68383
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Aug 2011 Posts: 154 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 154 | Thanks 48X! I will try that at home.
I'm going to send all my gauges to Bob's Speedometer. He will test them for free and if repairs need to be made, I will go from there.
