| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2000 Posts: 81 | I have a 1963 chevy SWB stepside, with the driver's door stuck shut. It's definitely something to do with the lock mechanism,(duh). :confused: I can get to the inside of the door but I don't know what to remove or destroy in order to open it up. Any help,  creative or functional is appreciated.
If at first you don't succeed, get a bigger hammer.
1941 Pontiac business coupe 1947 Chev Coupe 1969 GTO ragtop
| | | | | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | If you can get the inside panel off - pull on the metal bar that runs back to the lock. If you pull off the panel, there should be a stub sticking out of where the inside handle connects to. The stub and the device bolted to the door (called a relay, if you care) hook to this metal bar. If you are lucky, the relay is the problem and pulling on the bar will open it. IF you aren't the lock itself is jammed. Unfortunately the screws holding the lock on are only accessible when the door is open. I suggest you douse the lock several times with WD-40 or your favorite penetrating oil, then pull hard on that relay bar. There is a chance that the lock mechanism is jammed on the receiver portion on the door jamb - in this case the best thing to do is to hit the door with your shoulder from the inside - it should eventually open up. | | | | | Joined: May 2001 Posts: 46 Member | | Member Joined: May 2001 Posts: 46 | If you need to barrow a manual,give me a buzz.You must be close.I can here somebody yelling at their truck.  | | | | | Joined: Jul 2001 Posts: 140 Shop Shark | | Shop Shark Joined: Jul 2001 Posts: 140 |
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht- Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
