9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | I have a stock fuel pump on my 37 Chev 1/2 ton truck with a stromberg BXOV2 Carb. I want to reduce the pressure from the pump to about 2 1/2 pounds but dont really want to put in a fuel regulator I heard somewhere that if you pack out the fuel pump from the engine block this reduces the stroke on the mechanical lever therefore the fuel pressure. Has any one heard of this before? PS have attached a link to a recent photo of my truck http://s1260.photobucket.com/user/37Chev/media/Truck/20150607_142954-1_zpsubj05cyr.jpg.html | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have never heard of that but I don't think it would work. It would reduce the volume but I dought if it would reduce the pressure. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Thanks wrenchbener the guy who reconditioned the pump said the same thing just wanted to confirm with the experts | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | You need something like this, http://www.mamotorworks.com/vw/Prod...m-glass-filter-bowl-made-in-italy_319758 , it looks like it would belong on the truck. This place has one in the works, http://vintagespeed.comYou can use a modern type and mount it back under the cab. Run your normal line from pump up to carb (s), then " T " off it with a line running back towards the firewall, route this line down and back to the tank. Install the regulator out of site, then dump the excess fuel back into the tank or fuel line. The carb (s) will receive full volume of fuel at the regulator pressure. Dirt racers run fuel systems this way. If you regulate before the carbs, you receive reduced pressure and reduced volume. It also keeps electric fuel cool since fuel is always moving through them. Joe | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Joe H, Nice links. Thanks for posting them. It would be interesting know if that Edmunds reproduction is being made. The European one looks "period correct" (but, a little "pricey" - around $100). I have used this less-expensive style but have had to send a few back, probably dried-out diaphragms (that the sellers blamed on bad gas - maybe/maybe-not). | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | To change output pressure of a mechanical pump the control point for the pressure is the diaphragm spring. If you have a pump that you can take apart and tweek the diaphragm spring pressure you can lower the output.
"The pressure at which the fuel is expelled from the pump is thus limited (and therefore regulated) by the force applied by the diaphragm spring."
A secondary point is the output port opening size on the pump, but much more difficult to work...
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | |
