| | | Forums66 Topics128,113 Posts1,056,580 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | wanting to know the interchangeabilty of finders,grills, hoods, and doors, for 1947-1953, chevy to gmc. is the 1 to 2 ton cabs the same as 1/2 ton | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | StreetRod The fenders, grill, and hood on a chevy are different compared to the gmc. They aren't compatible. Go to the gallery and take a look at some of the trucks in there and you will see what i mean. The doors will work however. But during 47-55, there were minor changes. 47-50 use turn handle, no side window vent, 51 has turn handle no vent, 52-55 have push button handle and side vents. Hope this helps you out. | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | as for the cabs, i asked the same question, the answer was that are interchangable. Make sure it isn't a COE however. ( Cab Over Engine-a stubnose) | | | | | | Anonymous Unregistered | | Anonymous Unregistered | hood and grill are different, but front fenders are the same except for the parking light holes in the GMCs - a GMC fender and a welder with a small disk of metal will make a chevy fender.
All of the nose clip parts are common from 1/2 ton to 1 ton and then they get bigger at 1-1/2 ton on up. Cabs are the same from 1/2 ton to 2-1/2 ton. | | | | | Joined: Sep 2003 Posts: 16 Junior Member | | Junior Member Joined: Sep 2003 Posts: 16 | thanks Fox&Ken you have confirmed my thoughts. Streetrodally | | |
