| | | Forums66 Topics128,052 Posts1,055,718 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Hey all, I just got my Block and Heads back from the mechanics shop and there nice and clean. Now I would like to paint it, mmmm, probably orange. All I need to know is: Is it ok to just paint it, after covering everything up of course, without cleaning it. Or should I wipe it down with a rag, or with an air hose?
PS: The Heads can be painted too right?
- Shane
- Shane (ChevyToughRebel) 2 Trucks; -1955 3/4 Ton Chevy -1979 3/4 Ton Custom Deluxe 20 4x4 1955 Second Series 3600 GED = Git Er Done
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I don't know how well your shop cleaned your engine but I would take it out on the driveway and wash it with some Simple Green and a pressure washer and clean it out good inside and out. Use a rifle ram rod with a cloth patch to clean the oil galleys. Make sure you get All the leftover metal shavings out, or your going to be rebuilding your engine again. Once it's clean of all dibris and oil you can paint it. Block, head, oil pan or what ever strikes your fancy. Hope this helps George | | | | | Joined: Jan 2004 Posts: 158 Member | | Member Joined: Jan 2004 Posts: 158 | Oh, I did have them do a special cleaning with the block where the oil galleys did get cleaned, and the block was cleaned inside-out, same with heads. So, I guess I can just go ahead and get the paint and....paint it, if I do!
- Shane
PS: Thanks For The Help!
