| | | Forums66 Topics128,022 Posts1,055,381 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Anybody have any expertise dealing with rust around the beltline area of the cab? I have some pitted through areas. I know they can be filled but how do you stop rust from the inside of this union from recurring? Thanks in advance for any ideas. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Several years ago, Bob Adler (an expert on Advance Design restorations) wrote an article on this topic in "Pickups 'n Panels in Print". As I recall, he suggested cleaning off as much old paint as is possible and they dripping a phosphoric acid treatment into the seam (like Eastwood's OxySolv). I do not remember if he then neutralized with a basic solution (like Eastwood's Metal Wash). This would then have to be completely dried before epoxy priming (or using a metal etching primer and then epoxy). Maybe someone has a copy of this article (I cannot find my copy).
I think I would clean the metal and then drip in a rust converter (such as Extend). Then epoxy prime. This is what I did with factory-lapped seams in my (soon to be restored) suburban.
The cab seam is a problem area in Advance Design pickup cabs.
Tim | | |
