5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#1107264 06/09/2015 2:52 AM
I have a 63 truck and have ordered a dash wiring harness, which didn't match up exactly. After sending pictures and e mails, they (American Autowire) decided I have 62 wiring in my 63. I have a 63 manual and schematics but need a 62 wiring schematic. Specifically under dash to engine compartment. Can anybody help me out? Thanks
Sir Searchalot
Sir Searchalot
Mark the old with tape (just for kicks)take some photos, just for kicks, rip it out and install the new per the AAW instructions/diagram.
It does not matter if your truck had "62" wiring, old trucks are easy to wire. It's all more or less the same.
"The problem is" that I'm not changing all the separate wiring harnesses, just the underdash harness. The 63 and the 62 are not compatable (different plug configurations). Thanks for the electrical lesson, I've been chasing wires on that truck since 1975.
Sir Searchalot
Sir Searchalot
Understood. Took out that part. If you just want a schematic I'm sure there are schematics in google, in the available 62 manual or someone here may scan and send.
According to American Autowire my 63 truck has a 62 wiring harness installed at the factory. Possibily an early 63 using leftover 62 parts. All the same componants, all the same wires. It seems that some of the connecting plugs were changed. The main one is the colume mounted blinker switch (lwr) a 62 has a 6 pin triangle shaped connector, the 63 has a 8 pin cresent shaped connector. (Different plug configurations). My 63 has a 6 pin triangle plug. What does your 63 have for a blinker connection? There are a couple more examples like dash cluster harness,dimmer switch, temp sending unit,etc. Nothing major, and yes I could rewire it to work. But that's not what I paid for. I do not need a schematic to do this job. I would like one to compare a 62 to a 63, there are differences, minor, but different. Thanks for your help. I'll go to goggle for a schematic.
Sir Searchalot
Sir Searchalot
I have a 1960 GMC 4X4. I also have a 1960 and a 1963 manual. The 63 manual indicates a 7 pin crescent. I could not find a 62 schematic anywhere. My 1960 GMC manual shows a 6 pin Turn sig connector. looks like the horn wire may be the 7th wire, not run thru the 1960-62 turn sig.
Already sent it back. They're sending me a 62 harness. Should be plug and play when I get it
Sir Searchalot
Sir Searchalot
perfect solution. Glad you chose that route. Restock charge?
