| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I've decided to try to find a brighter 12V headlight than H4. Any of you found good replacements using 12V?I don't think I'll consider LED style due to high price.
Drew
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Don't take it personal, but if H4 isn't bright enough, you might need cataract surgery. I know from experience. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: May 2010 Posts: 20 New Guy | | New Guy Joined: May 2010 Posts: 20 | What kind of H4 housings are you using?
If you are using cheap China or India housings toss them and go with a good Hella, Bosch or Cibie housing. It is literally a night and day difference.
Are you using relays and are your grounds good? what kind of voltage drop are you getting at the headlight connector compared to the battery voltage?
Ted My ride but looking for a Deco Bolt for the wife.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Toolbox, Good advice. I think I will go that route for now. All my connections are new, but I will double check. Admittedly, electronics are my weak link. carolines truck, Wow! OK. That wiring is WAY over my head I think. With help and much plodding and patience maybe I could accomplish what you have done with your wiring. In the meantime I am taking Toolbox's advice. Thanks to you both for this info. cletis, I do have an eye exam coming up. At 75 years, who knows what the doc will find.
Drew
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I thought the lights on my F250 were too dim and needed the plastic lens polished. I had the surgery and found there was nothing wrong with the headlights. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Drew, there may be some truth in Cletis' remarks. My Retinal Specialist told me everyone will get Cataracts if they live long enough. At 75 I'm surprised they haven't found Cataracts already. They do mess with how you process light.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It used to be that they wouldn't operate until the cataract became mature. So there are a lot of us walking around with some cataracts in the process of forming. Since it happens slowly, we adapt and we may not know we have a problem.
