8 members (55shaker, Wheelie, Gdads51, baldeagle, Otto Skorzeny, ShopRag, 78buckshot, 1 invisible), 108 guests, and 2 robots.
Topics128,268
Posts1,058,384
Members48,485
#110641 12/03/2002 1:38 AM
What type of gun would be good for spraying small parts and easier to clean then a large cup gun?.Any recommendations are greatly appreciated
Doug
#110642 12/03/2002 4:39 AM
what kind of parts,and how good ofa gun do you want
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
#110643 12/03/2002 4:56 AM
I looking for something small and easy to cleanup. I will be using it to paint a few pieces at a time( backing plates, springs, axles etc.) but want to be able to cleanup fast and with minmal amount of solvents. I always try to buy the best I can afford within reason.
#110644 12/04/2002 6:25 PM
For small parts and easy clean up I'd go with a touch up gun. There's several makes on the market and some are very inexpensive. This place has one for $25.00 (not the HVLP one).
72 Sierra Grande - Maych
Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time.
#110645 12/05/2002 12:58 AM
Harbor Freight has a refillable pressurized spray canister. Sorta like a reuseable spray can. Never used one, but looks like a good idea and easy cleaning.
Dennis
#110646 12/05/2002 2:52 AM
I have been using the touch up type guns for both primer as well as colour with good results and they are easy to clean.
#110647 12/05/2002 4:38 PM
me 2 - been using touch up guns just like that from Northern and other places. and painted about 5 motorcycles with them.
Its a schlock up of a binks detail gun and works very well, especially with the current paint formulations that are designed to be used in an HVLP. One note though, you get a big paint fog, so make sure (especially in slow drying colder temps) that you cover everything else you don't want painted, because overspray will go everywhere.
I found one in a pawn shop once and they wanted $49 for it and I said you are crazy I can go (literally) next door and get one new for $20. They just looked at me like I came from another planet.
Getting harder and harder to get a deal at a pawn shop these days - they think they are sears.
