| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 35 | I have gone through the forums and haven't really been able to find a clear answer. I have a 1948 3800 DRW rig. Has anyone tried to fit 17" modern wheels and radials on these trucks? I am looking at something like this: http://www.wheelsandspinners.com/product.php?productid=1032&cat=62&page=1
Aaron V. 1948 Chevrolet 3800 216/4-spd 1979 Chevrolet C30 Ramp Truck 454/TH-400 1995 Jeep Cherokee 4.0/5-spd 1970 Ford F100 390/4-spd 1973 Ford Maverick 302/C4 2004 Honda Shadow 1100
"While driving yesterday I saw a banana peel in the road and instinctively swerved to avoid it᠁thanks Mario Kart."
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Something they're not telling you on that site, the rear wheels are meant for the outside dual only, you use a steel wheel for the inside dual. Dealt with plenty of those over the years.
Bill Burmeister | | | | | Joined: Jun 2013 Posts: 50 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 50 | When I had my 52 1 ton dually, I tried 17.5's and they would not even work on the inside rear. The factory 18's barely clear. 19.5's will work but are not easy to find with the early 1/2" lug holes and correct diameter center. I had a set of 19.5's but sold them to a member here. I know some have changed to a later rear axle to get better gears and be able to run a 16" wheel and tire. | | |
