| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Greetings! I'm working on a (couple of) 53's, and would like to find a good paint code, or at least one that will work for the gray/silver used in the 53's interior. I'd like to use PPG's single stage DCC to do the job. Also, I know 40319 is the formula number for Forrester Green, but it does not translate into the DBC system. Does anyone have a number for Forester (or even Juniper) that can be made in DBC or DBU? I got a cross reference code of 46296, but it looks way too light when I paint it, so that's not it. HELP!!!! | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | The PPG number I have for forester green is 40519, a little different from yours, but I had some made up, and it is very dark, matches the old paint chips I have that are in very good condition. I have a PPG number for what I am told is 47-52 truck interiors, it is 3613, but I had some of that made up, and was not happy with the color, I think that number is wrong. So I got some from Chevy Duty, which I am happy with. I notice they say it is for 47-53. No paint code on the can. | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | Sorry, you're right on the Forester code number, but I still can't formulate it. I'm taking a class and could make it myself if I knew the DBC formula. I'm holding out hope that somebody has a good DCC formula for the interior. I've got a color I may work with. My dad was a big gun collector and a lover of AD chevy trucks. The color I'm looking at is a newer chevy color named gunmetal poly. I can't imagine a more fitting combination on a tribute vehile. I'd be happy to pay for the formulas if I could make both myself. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I do not have PPG (Ditzler) codes for 1953, but the Dupont code for "Sheen Gray Metallic" (the interior color for all 1953 trucks, except the Suburban) is:
DUCO Stock Order Number: 740 DUCO Code: 202-81407
The following phone numbers are 5-6 years old. I hope that at least one number is still good:
PPG Refinish Technical Services: 440-572-6111 PPG Refinish Color Library: 440-572-6100 PPG Refinish Color Library fax number: 440-572-6871
Tim | | |
