0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#1105202 05/28/2015 6:18 AM
Hello to all
I have a 55 chevy 3600 pickup and had a question on the gauges. My fuel gauge ain't ready , sonic replaced the fuel sending unit and nothing so I'm assuming its the guage. Should the fuel gauge have a grind on it? My gauge has two prongs on it. Also my trucks wiring has no fuse box none what so ever.
frankielocs #1106234 06/03/2015 7:22 PM
Hello, Sorry I don't understand the grind?
The "Sender" post should connect to the green wire (Behind F)the "IGN" post should connect to the pink or light red wire (Behind E) no fuse required. Do you have any wires hanging back there?
frankielocs #1106236 06/03/2015 7:29 PM
double posted
grind = ground (probably)
frankielocs #1106240 06/03/2015 8:13 PM
Ah I see Thanks Tim!
I believe The sender grounds on itself. The Gauge grounds itself on the cluster housing. I'll look at mine tonight.
frankielocs #1106253 06/03/2015 9:46 PM
The sender top/mounting plate should be grounded. The quality of this ground can be tested with by a continuity test between the frame (or other good ground) and a sender mounting screw on the fuel tank.
frankielocs #1106314 06/04/2015 2:32 AM
May have to do some "grind"ing to get a good ground. smile
frankielocs #1107764 06/11/2015 9:16 PM
Moderated
Moderated
I have a situation where my fuel gauge and sender bench test perfectly. Then, in the truck the fuel gauge works great until I start the truck. Then it gets Parkinson's and jumps around, often up behind the F, but will sometimes settle at just the right RPM. This is a 12 volt conversion '53. I have had the alternator tested, and replaced the coil resistor, and added a ground at the tank. All gauge lights work good, so I'm assuming the cluster ground is adequate.
Suggestions?
frankielocs #1107986 06/13/2015 3:18 AM
If you have an intermittent "past full" symptom, you likely have an intermittent "no ground" situation.
Find a better (or cleaner) place on the frame for the ground wire coming from the base of the sending unit.
Carl
