| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I've been told that is a difference between the 1/2 ton and 3/4 ton long beds. What is that difference?
Regards, Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd be suprised - never heard that - maybe they were thinkin diff tween the "normal" long box and the 9' "extra long box" used on the 1 ton? or were confused about there not being a 3/4T short bed? or maybe they were just phord phreaks? Bill | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | On Chevy ADs, 1/2 ton has 6'6" bed 3/4 ton 7"6" bed, 1 ton 9" bed.
Frames and suspension were lighter for the 1/2 ton, along with 6 lug wheels. The 3/4 and one ton had a heavier frame and suspension and 8 lug wheels.
Fred 52 3600 69 C-10
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | GMC made a long bed 1/2-ton truck. article at Jim Carter\'s | | | | | Joined: Mar 2002 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 53 | I have a 59 – ¾ ton long bed. The bed measures 97” long.
Clem
Clem 59 Chevy 3600 New Hampshire
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Thanks for all the input. I had a chance to get under the trucks this morning and measure the mounting points. At least on the 65 C10 and 63 C20 there does not seem to be any difference on the mounting points, the beds should interchange without any problems. When I first took a measurement I thought there was an inch difference between the mounts closiest to the cab.
Regards, Larry
