3 members (dt235sd, cmayna, Hotrod Lincoln), 102 guests, and 2 robots.
Topics128,142
Posts1,056,490
Members48,442
Apprentice
Apprentice
Ive been reading this forum for some time now and have really enjoyed learning from all of you who are way more experienced than I. Never registered because I didn't have anything to say. Well finally I picked up a 1950 1/2 ton of my own last month. And now I have all kinds of things to say.
When I first looked at the truck I new it would need a lot work. So far their has been a lot of surprises (good and bad). It seems I am fixing more problems caused by previous owners then by nature (Arizona truck, not to much rust). I thought the floor and toeboard were in good shape until I started removing the floor covering and found out the previous owner had torched the toeboad to fit a AMC 343 engine in it. He covered it up with tin siding and riveted it in. Anyway, now I need to replace it. The floors pretty shot too.
Should I buy a new patch panel toeboard or can I make one relatively easy? If I do make my own what should I be aware of? How should I brace the cab before removing whats left of the toe and floor board? I'm going to be carpeting so I don't need the original look. Also, I will be putting in a chevy 350 if that make a difference. Thanks for your Help.
Everything you know is wrong.
You can buy new toeboards pretty cheap. You shouldn't have to change it for the 350.
Paint & Body Shop moderator
Quote
Originally posted by OldCarKook:
when will Ramblers finally rest in pieces?
Shouldn't that be rust in pieces?
Fred
52 3600
69 C-10
"Kook" there's a fella near me in North Manchester, IN that recently built a big steel building, has orig Rambler signs out front and in windows and now sells parts for old Ramblers. I bet he wouldn't like what YOU said!! grin Older Ramblers ran OK, used 20 yr old systems, but Sure were UGLY! grin
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
Ramblers used to be ugly. Now they're samples of american chic. We've a young neighbor girl who drives a nice 64 Rambler American. She gets more comments and conversations than her dad does about his 66 GTO. And the comments are about her car.
"Happiness equals reality minus expectations" - Tom Magliozzi
Apprentice
Apprentice
It seemed kinda weird seeing an AMC engine inside a Chevy truck. Isn't it usually the other way around? AMC owners are aways ditching their engines for a chevys. Not that I have anything against AMC engines. Hope I can find a buyer for it though. Don't even know what their worth.
I Bought a 53 Chevy pickup 2 years ago with an AMC 360, 64 wagoneer frame, 72 jeep drive line, it's a 4 wheel drive pickup. Engine has great power, 3.73 gears, turbo400 chevy trans. Take a look and see, It's sits right, drives great!
http://home.attbi.com/~sworfktn
