5 members (Charles in CA, mick53, Gray_Ghost, BC59, klhansen), 168 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
I'm in the middle of installing my new wiring harness on my 55.2 12 volt. As I've gotten to the wires coming from the turn signal switch on the column, it's obvious they are in really bad shape and I'm contemplating replacing them due to how worn they are. I've done some searches on Stovebolt and goodle to attempt to try to figure out:
1. What kind of turn signal switch I need
2. How I got about replacing them.
Here is my column: https://flic.kr/p/aUmwhX
https://flic.kr/p/aUmstD
Wires: https://flic.kr/p/tUUf5s
Harness: https://flic.kr/p/tXnkfg
Any help/advice is appreciated on this.
1955 GMC 100 Series 2
Maybe you can get away with just using this, and save some money.
http://www.classicindustries.com/sh...switches-fuses/?q=turn%20signal%20switch
Brian
1955.2 3100 Truck
Just the switch should be all you need.
LMC sells the same part for $14.95...$10 cheaper than Classic Industries.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks guys. With the help of Bill from Hot Rod Wires, I was able to get the new harness hooked up to the correct wires on the column and by some magical chance - the switch works. Will still put it on the list of things to replace this winter though.
I used a Hot Rod Wires harness in my '56 nearly 10 years ago. I am extremely happy with it.
