1 members (Peggy M),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | I am removing what looks to be an aftermarket sm420 from my 55.1 Chevy. There is still shift linkage on the steering column from an old trans which pointed to aftermarket. I am removing the trans for service and cannot seem to break it free. I'm sure largely in part due to my ignorance. I have removed the top two bolts but I don't see any others that are holding it on. In a few of the pictures I have pointed out which bolts I have removed in blue, and what looks like there should be bolts in yellow, but there weren't any there. Any help would be appreciated. https://goo.gl/photos/AJ7ctgZWQpgvUzcz9
1955.1 Chevy 5 window 3100 Instagram - @1955.1chevy
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | There are two bottom bolts. Take off the pan that might be under the clutch housing (screws can be reached with a screwdriver through holes in the frame cross-member). There are two transmission bolts from the lower inside of the clutch housing. ----- Transmission Removal - steps 9-11 http://chevy.oldcarmanualproject.com/shop/1955truck2/55ctsm0751.htm | | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | Thanks Tim!
I was reading the 54 manual which says basically the same thing, but your hint to go through the holes in the crossmember (that was caked with about 2 inches of junk) did the trick.
Step 11b should have been: Make sure you have a buddy to help lift it up and out of the truck. It's heavy.
:P
Thanks again!
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Danthemanmj23,
I did not know/think about those holes until reading about them, here.
Regarding the need for a buddy: when I was much younger, I used to install remove the SM420 by myself from below ("by hand"). I do not now believe that I was able to do that. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Tim, don't they call that young and foolish! | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | I had it easy with my SM420 removal and installation. I borrowed a tranny lift from a friend. It had pitch, yaw and roll adjustments which made it really, really nice for lining up on installation. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I call it: I wish I was young, again.
Actually, I get hernias - in the early 70s (my early 20s) I bought a cheapo K-Mart (pre-Harbor-Freight) floor jack for lifting air-cooled VW engines. | | | | | Joined: Jun 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 39 | Goodness sakes that is some engineering Denny! Awesome!
I can tell those days for me are coming faster and faster, and I'm only 27...
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You ain't even come close to hitting your prime Dan, at 27 I was still trying to figure out who I was and what direction I wanted life to take me. Oh, and what you will learn in the next fifty years will amaze you when you look back on it.
That SM420 swap was very popular back in the day. Your 3-speed obviously was swapped out for the 4-speed. But that transmission was also an option from the factory and there are many 3100 trucks which originally had an SM420 in them at delivery. dg
Denny G Sandwich, IL
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I swapped my 3speed for the SM420 by myself too... after taking out the three speed I thought putting the SM420 by myself would be a piece of cake... not so much... I was sore for days! And I was only 23 at the time!! | | | | | Joined: Mar 2022 Posts: 1 Moderated | | Moderated Joined: Mar 2022 Posts: 1 | You think it is hard at 23, you should try it at 75! I managed with a transmission jack. The hard part was trying to keep it from tipping on the jack since the sm420 doesn’t have a flat bottom. I got it with my second try. I am a bit sore today, a lot sore I should say. | | | | | Joined: Feb 2019 Posts: 4,480 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,480 | Just to let you and others know, you posted on a thread that is eight years old!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | |
