| | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | My '59 hood is painted and ready for mounting, but I've a question about the hood braces. One of them is bent, and I've seen similar on every Task Force truck I've looked at. I'm assuming the bend is to provide greater clearance for the air cleaner, eh?
Unfortunately, I can't remember which brace goes where, and if the bend should be toward the front or rear. The Factory Assembly Manual doesn't show any bend in either brace.
Anybody help me out here?
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Bend on mine (58 GMC) is at the back with the rod running from Pass front to Dr rear
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | My 55.2 3100, the drivers side rod has the bend at the back on the pass side. The two rods appear to be welded together where they cross. Don't know if this was done at the factory or not.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | |
