0 members (), 119 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
How hard is it to rebuild a waterpump? It is off a 1957
283 and I want to keep the original look and housing. Thanks for the help.
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
You can't buy the bearing/seal separately any more. At one time
they were available from the Chevrolet parts department. So
you're best bet is a rebuilt from the auto parts.
dg
Denny G
Sandwich, IL
3B Offline
Hy niobrarafun, I think you should be able to find a correct rebuilt pump from one of the suppliers. As far as I know the shaft/bearing assemblies have never been available to the general public, the seals you might be able to find, you'll need a press and a jig to set the impeller to the correct height. The industry has left this job to specialist rebuilders for years, hope that helps.
Just seen a rebuid kit on E/bay for $55.00. I also got done looking up a 57 283 water pump at Rockauto.com and they had some there for less than $20.00. ZipCorvette.com also shows a rebuild kit for $50.00.
Brian
1955.2 3100 Truck
Gp. 1.003 Pn. 3704162 water pump shaft assembly w/bearing, 4 11/16” O.L., $3.45
55-57 All. It went thru many parts number changes after that but was the same shaft
assembly.
I sold a lot of them and installed them at home when I was a Chevrolet parts man back in
the early 60’s.
As Brian said, you may get lucky and find one on evil bay but the rebuilders have
cornered the market and are the only ones that are able to get the new assemblies now
a days.
Much like the kits for the vacuum wipers, which are dominated by one rebuilder today
who won't sell you kits, only units rebuilt by them.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Thanks for all the info. I really appreciate it.
