| | | Forums66 Topics128,191 Posts1,057,348 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Just about to finish up my first door. A few questions.
1. The window channel kit included "side window rubber bumpers" marked with Jim Carter p/n W1230. Where do they go?
2. Does some sort of windlace or weather seal attach under the inside door skin and window trim?
3. Attached to the front and rear sides of the door frame are 2 horizontal braces. When I originally disassembled the door,there were some rubber pieces between these braces and the outer skin. Is there supposed to be something there? If so, what are others using for this?
Bob
BobS46
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Bob, I'll give this one a shot.
1. Not sure about the rubber bumpers, they might go inside the door where the window comes to rest in the down position.
2. There is no windlace or anything attached to the doors. The windlace goes around the door frame and there is a rubber seal along the lower part of the door opening.
3. Those pieces of rubber are to prevent the door skin from rattling against the horizontal braces. I covered the entire inside of my doors with sound deadening material so I didn't use them.
Hope this helps George (46forme) | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | THanks,
That did help - confirms what I had suspected.
BobS46
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Bob, This photo may help. Harold Window Bumper Photo of Window Door Glass Channel Door Glass Channel Photo of seal between door and lower floor Seal
Harold Is a restoration ever finished? | | |
