6 members (Southerntruck, 1955 1 Series, cmayna, Otto Skorzeny, Hanks custodian, wilbur53), 89 guests, and 0 robots.
Topics128,156
Posts1,056,870
Members48,456
Having trouble finding some wheels to clear the calipers. Found some chrome 6 lug rally's with a 3.5" backspace but they rubbed even with a spacer. Maybe I need to go to a 4" backspace? Anyone else had the same issue? Probably going to order wheels from wheel vintiques, just unsure of the backspace I need.....
4" backspace would make it worse. What kind of calipers does the kits have? I find it odd that the 6 lug Rallye does not clear, considering that they were used with disk brakes on the oem application that used larger calipers than most of what is offered in the aftermarket. Perhaps you need to bump up to 16" wheel fi they're using later style dual piston calipers, which the 15s will not clear.
Bill Burmeister
Gas Pumper
Gas Pumper
Yeah, I couldn't be bothered, so I just called up Wheelsmith and ordered new rims that are made for this modification. I think I paid $94 each. Its just too iffy in my opinion to grind the calipers, or the wheel itself, or whatever. Wheels are very important and something that should be sacred from all the hacking. wheelsmith.com should get you there. They know what you need when you tell them and get them out right away.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks for the info guys.....I'll check into wheelsmith
Gas Pumper
Gas Pumper
http://devestechnet.com/Images/Restorations/1950B/D50b00031lg.jpg
http://devestechnet.com/Images/Restorations/1950B/D50b00030lg.jpg
http://devestechnet.com/Images/Restorations/1950B/D50b00037lg.jpg
Those are called The Smoothie. Its a vintage look but is designed for modern radials. Mine are 15's w/ 6 lug pattern. They have the correct hubcaps made for their rims. If you already have your own hubcaps, they make an adapter. Good company and prompt service.
Deve
The Think Tank
What's the back space on your wheels?
Gas Pumper
Gas Pumper
I just measured and its about 4 inches, but not exactly sure. I told customer service it is for a 1950 (same enough) truck and why I needed them and he knew exactly what to send.
Deve
The Think Tank
Sounds great! Your chassis looks awesome! Is that powder coated?
Gas Pumper
Gas Pumper
No, its paint. smile
Deve
The Think Tank
