5 members (Chip O, Hotrod Lincoln, Otto Skorzeny, TUTS 59, EchoBravoSierra), 102 guests, and 5 robots.
Topics128,077
Posts1,056,013
Members48,433
#1105604 05/30/2015 10:49 PM
My 53 half ton is all 12 volt. rebuilt 12v guage from classic new sender. turn on the key and guage goes to between 1/4 and 1/2. right now the tank is about 3/4 full. hot wire to the e sender wire to the f. what should i be checking for.
basham #1105608 05/30/2015 11:42 PM
Check with "Classic" about the ohms for the sender.
If you have the original sender, it is 30 ohms. It it is a 90 ohm gauge, that might be the problem/explanation?
http://www.tanksinc.com/index.cfm/page/ptype=results/category_id=159/mode=cat/cat159.htm
