1 members (moparguy),
113
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 30 Junior Member | | Junior Member Joined: Oct 2003 Posts: 30 | hi..everyone has been a great help...WHAT A BOARD !!!! i'm into the interior now....trying to figure out how to get the steering colum out!! hummmmm....i unbolted the gear box..seems to be a gear!!! go figure ...but does the gear come out so that i can pull the column from the inside ...trying o figure this one out ...or does anyone know where i can get a book on how to diss.. the beast of a truck !!!built chevy tough back then i guess,,,,lol...thanks in advance ........regards gary | | | | | Joined: Jul 2004 Posts: 39 Junior Member | | Junior Member Joined: Jul 2004 Posts: 39 | Hey Gary, You need to disassemble the column from the top. Steering wheel etc. even the top bezel comes off to allow the column to come out the bottom. Good Luck Paul 1958 PU
Paul
When you do a good deed, get a receipt just incase HEAVEN is like....the IRS
| | | | | Joined: Sep 2002 Posts: 438 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 438 | Careful, as you don't want to "unpack" the steering box's ball bearings. Others suggest taking the steering weel off and unbolting the box+column from the frame after marking the position of the pitman arm. Then slide the box plus column out of the hole in the firewall. It will make your assembly easier and not require a repack of bearings inside the actual steering box. | | | | | Joined: Oct 2003 Posts: 30 Junior Member | | Junior Member Joined: Oct 2003 Posts: 30 | HEY GUYS ,,, thanks for the info..I was thinking the same when i started to unbolt everything ..but i wanted to confirm my guess!!!!I hope that i didn't screw up the gear box...i'll try and put it back together...you guys are awesome!!!alot of help to a NEWBIE!!!......LOL.....HOUSTON54'S pickup looks like that it is comming right along......I'M hopeing to have a rolling truck come this summer.....I stopped working on the house so that i could focus on the truck this winter ....BURRRRRRR... I need to get some heat in that there shop...lol.......thanks guys ...regards ....gary | | |
