9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible), 57 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1105457 05/29/2015 11:01 PM
My 59 GMC 327 V8 (Pontiac) just got an engine rebuild. Part of it was a new temp sender on the engine. Now, the temp gauge pegs past H after the warm up. Is there a way to recalibrate the gauge to dial back the needle into the more normal operating range? (the engine is not overheating, just the gauge reading high.)
Michael Merriman
1959 GMC 100-8
Saint Helena (Napa Valley), CA
I'd say the new sender was put in with teflon tape and it can't ground properly. The sender is a variable resister to ground. I use pipe dope called T+2.
X2 on the grounding, I just had the same issue with one of mine pegging. My issue was lack of ground on the gauge cluster housing but acted the same way. Once I got it grounded properly the gauge worked fine.
Is teflon tape THAT good of an insulafor on pipe threads?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Took off the teflon tape and reinstalled. Gauge still pegs past hot. Any other ideas?
Michael Merriman
1959 GMC 100-8
Try another gauge.
Might check this out for grins and giggles.
I ran across this a while back and had to change out the sender.
http://www.lectriclimited.com/mainpage.htm
You must have a mismatch between the sender and the gauge. Rock Auto has senders for all 59 GMC engines for around five bucks. For that price I would get one I KNEW was for a 59 GMC.
Evan
