2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1105071 05/27/2015 5:34 AM
I've been putting together a 3spd for a '37 sedan.
I have several other g/boxes in bits and noticed that the pickup ones have a spacer between the rear bearing and the U joint yoke.
The car trans is without this spacer , but it seems like it should have one, maybe 1/4" long?
I cannot find an exploded diagram to verify this , or any info that says how to remove the current end float in the output shaft.
Anyone done this ??
Dusty,
is this diagram of the 38 passenger car transmission of any help? Shop Manual diagram
1951 1 Ton Completed
Thanks , yes that works for me , I dunno why it was not pictured in my '37 manual , but I see I just needed to draw the main output shaft into the rear bearing a little more.
Thanks for your help.
Update;
Well I was wrong ...... I had fitted the output shaft correctly into the rear bearing .
What I had not noticed was the circlip groove for retaining the rear bearing in the casing was slogged and that is causing the end float I was unhappy with.
Back to the drawing board for a fix for that.
Well I could not see a way to economically repair the case , so I just put a little 601 loctite around the outer shell of the bearing and hope it will be enough to take the load. Time will tell.
