4 members (BCBill, Gdads51, Gray_Ghost, Otto Skorzeny), 133 guests, and 2 robots.
Topics128,101
Posts1,056,175
Members48,436
#110531 12/01/2002 12:43 AM
Is there any way to replace the door hold open springs witnout removing the hinge pin? My hinge pins are in very good condition, I hate to remove them just to replace the springs, but I don't see any other way to do it. If there is a way to do this without removing the hinge pins I would sure like to hear about it.
How tough is it to temove the pins? Can I just grind off the end and pound them out?
Any help would be appreciated.
#110532 12/01/2002 2:40 AM
I may be wrong, but I believe you have to remove the pin to put in new springs. A 50 year old truck probably needs new pins anyway, mine certainly did. I find the best way is to drill the old pins out with a drill press. If you use a letter "R" drill bit, you will have a perfect size hole for the replacement hinge pins. Be sure to use a drill press to get the hole straight, then reassemble with the new springs, and pound in the new pins, they will stick out the other side, just grind that end off.
#110533 12/02/2002 3:56 PM
With some penetrating oil (PB Blaster) and a little heat, mine tapped right out. They do have to be removed to replace the springs. Have fun.
#110534 12/05/2002 6:56 AM
Brian, thanks for the advice on the "R" drillbit ... I got the kits but no instructions at all. I have all my hinges off the doors would life be a little better if I put one end on the door or just stick them in a vice?
#110535 12/05/2002 5:33 PM
I found this link helpful when I rebuilt my hinges and replaced the springs:
http://www.classictruckshop.com/door_hinge.asp
Tim
#110536 12/06/2002 4:31 AM
TC - thanks for the headsup on the classic truck shop. What a lot of great information ...
#110537 12/06/2002 3:09 PM
Thanks everyone for all the information. Looks like I just need to jump in and get the work done.
#110538 12/14/2002 4:09 AM
Actually a pretty simple job. One hinge pin came out with a punch and hammer. The other one moved about 1/16" before it refused to move anymore. I had to drill that pin down about 5/16" and then it pounded out rather easily.
I used a 5/16" bit to drill out the old pin, a 11/32" bit to drill out for the new pin and a 27/64" bit to drill out for the bronze bushings. I did have to spot weld the spacers back on the brackets, they broke off with all the pounding.
Everything went back together with the hold open springs very nicely. The pins were a good snug fit. I had to use a small hammer to tap the pins through the hinges, cut the other end of the pin off leaving about 3/16" through exposed and used a center punch to peen the cut off end.
Took about three hours to do both top hinges and most of that was spent figuring out what size drill bits to use.
Thanks for all the help, the link was invaluable. I would have posted pictures of the process, but i don't have a clue how to post a photo.
