2 members (Gray_Ghost, RLB),
194
0
Mod | | | Forums66 Topics128,080 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | I have been trying to install my spare onto the original tire carrier under my short box 3100. My problem is that the spare never seems to get tight against cross frame rails.Is it supposed too be tight or is a slight wobble normal? Any info is appreciated. Thanks | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | It's been a fairly long time since I had any dealings with the original style carrier on anything older than 2000, but I seem to recall the AD's had a bit of a gap which allowed the tire to move a bit.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year A-D?
My 1954 spare tire does not move at all. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | My 50 is sung
Otherwise it makes for a noisy ride | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | It's tight on my 49 also. You may need to use spacers on the threaded hook inorder to get it up tighter.
Good luck Dave | | | | | Joined: Sep 2012 Posts: 306 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 306 | ** My 51 and 52 are adjustable at both ends of the carrier, have never had a problem as you describe. The end near the left rear tire can be a chore to adjust if it has not been adjusted for years. ** | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | My 50 is the old style I think like yours Canada. Mine does not hit the cross member or anything else. It will sway just a bit under the truck using the J-Hook. I thought they were designed that way. The tire would hit the slide before it hits the bottom of the crossmember? I could be wrong. I noticed that you would have to add spacers or do something extra to get it that far up. I don't want mine to touch because that means scraping the paint. The way it is built, it isnt going anywhere in any case. Very sturdy design.
I didn't like the sway, so I decided to incorporate the system into my trailer hitch system. Now its solid as a rock. | | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Denny would know for sure. DENNY!!!!!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | And I rest my case. The top saddle is designed to set solid up against the cross member. Now you know for SURE. Denny knows! I think he was there. LOL! Seriously Thanks Denny!
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Thanks for info Denny. I got a hold of an original tire carrier but was missing the top saddle peice. I had never even seen how it all goes together so I built the top saddle myself. I assumed that it squeezed the side wall of tires downward. but I see now that it actually only touches the center of rim and both its ends are bent upward to come against frame cross member. Thanks again
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Put an add in the swap meet, they come up fairly often. The 3100 is much more common than the 3600, there is a difference and those are pretty hard to find.
dg
Denny G Sandwich, IL
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Denny, Isn't the tire carrier in your photo for the 3/4 ton? The parts book shows a different carrier for the 1/2 ton or am I reading something wrong? Harold Spare Tire Carrier
Harold Is a restoration ever finished? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | The illustrations in the parts book do not show the exact part used on any specific vehicle. They are generic illustrations meant to direct you to the proper group for that family of parts. For instance, they may have a wheel illustrated and labeled as group 5.803 but there are nearly five dozen different part numbers for wheels listed. Obviously they couldn't illustrate all five dozen of them. This has been a subject of debate in the past, but my feeling is that the illustrations of the carriers show the pre-AD style for the 1/2 ton and the AD style for the 3/4 ton. In reality the early 3100 and 3600 AD carriers are very similar. The only difference I've noticed is in the rear mount for the slide. In fact, the carrier on my truck is actually a 3100 with a new rear slide mount that I fabricated. The 3100 and 3600 crossmembers are in different locations and at different heights. http://www.pbase.com/dennygraham/image/160161998/large Denny Graham Sandwich, IL
| | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Danny your pics really helped me to understand how it all goes together. I have made my own top bracket and it works great. Thanks. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | I am posting photos of the spare tire carrier as information. The photos with the tire is a 1950 3100. The other photos are 1942 - 1946. Harold Spare Tire Carrier 1/2 ton
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The cradle in the pic is upside down | | |
