| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | On the drivers side there is a bracket that attaches the inner fender to the firewall. Is there one on the passenger side also? 1948 1/2 chevy | | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | If you are referin to the what I think you are the answer is yes. There should be 2 one on each side that angle out to the fenders from the firewall. | | | | | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | On my 49 there was only a bracket on the driver's side. It is there to mount the emergency brake pedal shaft and the inner fender bolts through it. On the passenger side the inner fender bolts directly to captured nuts in the toe board. Somebody else will ring in if this is not correct. | | | | | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | Anyone with an assembly manual please help? | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | No book, but had the same question on my 52. The bracket is only on driver's side as rwise said. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | And on my 49, the bracket is only on the drivers side. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Yes, that is the way they are, the bracket is only on the driver's side. I think the previous comment to the contrary may have been referring to the little filler pieces that go on top between the inner fender and the cowl. I have only seen a few trucks with those in place and they are there to block spray from going down in, I think. | | | | | Joined: Jun 2004 Posts: 336 Member | | Member Joined: Jun 2004 Posts: 336 | And the assembly manual confirms what everybody is saying...
Gord 1954 1/2 ton 235 4 speed
| | | | | Joined: Apr 2001 Posts: 43 Member | | Member Joined: Apr 2001 Posts: 43 | | | |
