| | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | I bought 2 replacement doors for my 46 1/2 ton because mine are rusted out at the bottoms. I installed them on the truck today and they are not even close to fitting, I can't even close the doors. My old doors fit and closed very well. My thought is to remove my old door hinges and install them on the new doors. Any thoughts or experience? :rolleyes: | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Rusty46: IF you can get the hinges off that may be worth trying, but those hinges are not going to be easy to remove. How far are the doors off? There is a certain amount of adjustment you can make to the alignment with the door on the cab. The 46 GMC shop manual has a pretty good explaination. (there is nothing about this in the Chevy shop manual). If you need more info on adjusting the doors per the GMC manual let me know. Good Luck George | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hi 46forme, thanks for the reply. I was able to remove and exchange the door hinges but it didn't help. I did not see any provision for adjustment. The doors are at least 1/8 inch out of alignment. I have not attempted to remove the cab hinges as yet. I would appreciate any information you have on door adjustment. My Chevrolet shop manual, as you said, has no info on adjustment. Thanks for the help George.
Regards, John | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Rusty46; The information in the GMC manual is about 2 pages long. I don't have the facilities to post them here. If you want you can email me directly and we can make arrangements to get them to you either by snail-mail or fax. Basically depending on which way the door needs to move you would put a block in the door jam at either the upper or lower hinge and push the door closed. This actually springs the hinge and moves the door into alignment. There is more involved than this but you get the idea. It sounds scary to be doing this but it works. The manual explains the whole process. George | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | 46forme I have not been able to contact you by e-mail. I would very much appreciate a copy of the information you have regarding 46 GMC door adjustments. | | |
