3 members (tesa, Hotrod Lincoln, Nick in Manitou), 169 guests, and 2 robots.
Topics128,088
Posts1,056,002
Members48,430
#1104762 05/25/2015 9:18 PM
When I finished my truck I bought a set of tires from a local small supplier and truck alignment shop. Everything on the chassis was new. On the alignment they said it was off just a little on toe. I set it with a ruler when I put everything together. Moved from Mo to AZ, been driving it for 2 years and it always felt as I was a drunken sailor. Sorry you Navy guys. It would just go left then right. Always correcting it. You know when you get a feeling and it just wont go away. I pulled out my tape and it 3/8" toed out. Moved it back to 3/16" toe in and what a difference. Just rambling but do you need to check everyone's work? Sorry for complaining.
As a former drunken sailor we do not mind one bit.
As one who believe if you want it done right do it yourself, I agree if you let some one else work on things you better watch them, it did not used to be that way..
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
H Online: Content
We set the toe on the race car with a couple of flat aluminum plates held against the tire sidewalls and two tape measures, one ahead of the tire and the other one behind. We had a couple of 1/8" wide slots cut into the plates to hold the tapes steady, and just compared the front and rear readings. Simple, easy, and accurate, and VERY inexpensive!
Nice, Jerry
We use one of these old fashioned Wheel a Matic scribes.
http://www.wheel-a-matic.com/page9.html
It was cheap back in its day and it is simple.
Jeg's toe-in plates
Drill a hole in the top and bottom of the right and left side of each plate - use 2 bungee cords to hold plate to each wheel (run behind wheel)
tool like crenwelge's (I have an old HF version - no longer listed for sale)
H Online: Content
Be sure the wheels are pointed straight ahead when checking toe- - - -it increases somewhat as the wheels turn away from dead center.
I set mine that way, even though I had access to a Hunter Hawkeye aligner.
Bill Burmeister
Sharon Danella, must be the same guy did the alignment on my truck. When I checked it was toed out 1/8th of an inch.
I use a tape measure.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
