4 members (Woogeroo, klhansen, jay d, 1 invisible),
130
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | I have a 56 bel-air with a 283 hooked up to a power glide. I have started noticing a puddle of trans fluid on the barn floor back where the trans is connected to the drive shaft. Could this be a rear seal going bad? Have never worked on a powerglide before, can the seal be replaced in the car or will I need to drop it out. Thanks for any help guys. | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | The seal can be replaced in the car. The driveshaft will have to be removed. The seal is a common part available in most parts stores. That may not fix the problem, however. If the rear bushing is worn the seal likely won't last very long. The rear tail housing of the transmission will need to be removed to replace the bushing. Fred
| | | | | Joined: Feb 2004 Posts: 29,958 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | Snap-On makes a bushing puller/installer that can be used with the tailshaft housing in place, but very few shops have them. It has expanding fingers that can be slipped through the bushing with the driveshaft removed, then an internal sleeve is slid into place to expand the fingers. A few taps with a slide hammer removes the bushing, and the same tool is set up to drive a new one into place. A well-equipped transmission shop should have that tool. The high school auto shop where I taught for 30-something years had a set of those pullers. Jerry
