0 members (), 133 guests, and 4 robots.
Topics128,186
Posts1,057,211
Members48,465
Living in Florida I am considering adding A/C to my pickup..Tell me your happy stories or bad experiences
and help me make up my mind..
I used old air products and used the version that hides the vents and controls behind the speaker grill. I routed and made my own hoses. Fitting the vents behind the speaker grill was a royal PITA. The system works perfectly. I installed a condensed fan as well.
Gas Pumper
Gas Pumper
I have that same system in mind for my build. What did you have to do to get those vents in there? Is the condenser fan optional? What kind of cutting did you have to do to get that fan in place? I am wondering what I should do now before the cab is painted and things are not finalized. Did you make a plate to cover the heater hole or is that area used?
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks David...That is the system I was interested in..I like the fact that it uses the speaker holes for the vents and not a hang down unit..More work but I think it will look nicer...If I go with it I am sure I will be asking you questions..
Thanks again,
