| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 19 New Guy | | New Guy Joined: Dec 2014 Posts: 19 | Living in Florida I am considering adding A/C to my pickup..Tell me your happy stories or bad experiences and help me make up my mind.. Thanks, Bill
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I used old air products and used the version that hides the vents and controls behind the speaker grill. I routed and made my own hoses. Fitting the vents behind the speaker grill was a royal PITA. The system works perfectly. I installed a condensed fan as well. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have that same system in mind for my build. What did you have to do to get those vents in there? Is the condenser fan optional? What kind of cutting did you have to do to get that fan in place? I am wondering what I should do now before the cab is painted and things are not finalized. Did you make a plate to cover the heater hole or is that area used? | | | | | Joined: Dec 2014 Posts: 19 New Guy | | New Guy Joined: Dec 2014 Posts: 19 | Thanks David...That is the system I was interested in..I like the fact that it uses the speaker holes for the vents and not a hang down unit..More work but I think it will look nicer...If I go with it I am sure I will be asking you questions.. Thanks again, Bill | | |
