4 members (sron48, Shaffer's1950, Wally / Montana, 1 invisible), 40 guests, and 2 robots.
Topics128,090
Posts1,056,022
Members48,430
#110437 02/07/2002 1:53 AM
I've got a 1953 GMC and the steering wheel needs to be restored. Has anyone attempted to do this and how difficult of a project is this? Thanks in advance for all the great info. grin
E-mail me and ill forward you a copy of an article on how to repair a steering wheel.Same for anyone else that wants it. [email protected]
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
Buck, I bought a small cutter for a Dremel Tool and chucked it into my air drill. I vee'd out the cracked areas down to the core of the steering wheel. I mixed up some PC-7 epoxy and filled the cracks, smoothing it with lacquer thinner on my finger. I let the epoxy harden and hand sanded the epoxy back into the shape of the original wheel. The sanding was time consuming. I did it a little at a time over a period of a couple of days. I primered it and shot some lacquer on it. The wheel looks like new. I am sure you could do a nice job on your wheel..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
Bill, I'll give the PC-7 a try. Where did you get the stuff? Is it available everywhere? wink
Bill M
What primer if any did you use on wheel? Have you driven it enough to see how paint is holding up? My 65 GMC wheel is perfect except for paint being worn off outer edge and I have paint here if it'll hold up I'll sand and paint it.
Buck,
I restored mine pretty much the same way Bill describes and recorded the process on my website. Here's the web page:
Spifin\' up the Steering Wheel
The PC-7 epoxy can be obtained from Eastwood in the kit, Chevy Duty and some hardware stores, I believe. Good Luck.
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
Judd, I used rattle can primer from Napa and then painted it with a few coats of Dupont Lacquer that I bought from Jim Carter. I did the job this past spring and drove the truck about 2000 miles over the summer and fall. The paint is holding up nicely.
Steering Wheel
Bill M
53 GMC Hydra-Matic
Home Page
Bill M
Great! I'm polishing my ait brush up!
Nice truck interior I love the radio ( coool ).
53 4 me
Bill, What color is your dash ? Is that the stock champagne ? Looks great.
cool
Craig
cmayna, The dash was already painted when I bought the truck. I think it is the stock champagne, but I cannot be sure..
Bill M
53 GMC Hydra-Matic
Home Page
