5 members (66flea, cmayna, Wally / Montana, walter74, Forty9), 110 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
I have a chance to get a 56 261 from a Canadian Pontiac Car. Any thoughts on this year? Should i be looking for a different year?
3B Offline
Hy wolffcub, I believe that 261 would be the same as the one produced up to 1962, the Canadian Pontiac car engines only used bypass oil filtration and did not have the larger ports for oil circulation that their American cousin truck engines of the same period had, hope that helps.
A difference between the Canadian Pontiac 261 and the Canadian/USA truck 261 is the Pontiac 261 (only sold in Canada) uses hydraulic lifters. All truck 261s came with mechanical lifters.
Crusing in the Passing Lane
So, to answer your question, it is a good, desireable engine.
I drove a 55 Pontiac 261 years ago and it was awesome. We also had a 1960 Pontiac with the 261 and it was really nice too.
1951 1 Ton Completed
So took a close look at the engine. Looks alright. Block number check out to be a 55-57 261. The head is actually a 848 one already so things are looking up. Can be turned over by hand so it not seized. Oil pan looks to be in mint shape and also got a second valve cover with Chevrolet stamped into in like what the corvette has. Guy might even have a second 848 head he will toss in.
Only thing is that his buddy took half of the valve rockers frown
Great guy....he actually is just giving me the engine and stuff for free.
Nice find.
235 rockers will work fine.
My Blog
just need to find some with the shafts now.
