9 members (wilbur53, Otto Skorzeny, Greg_H, 68ironhead, WICruiser, Gdads51, Shade Baby, rinemb, 1 invisible), 243 guests, and 1 robot.
Topics128,095
Posts1,056,075
Members48,433
#1103977 05/21/2015 6:40 PM
I have never been able to get this old beast to run right. She has a flat spot just off idle and acts like its running lean since the idle speed improves if I restrict air by placing my hand over the carb. I rebuilt it and raised the float level to no avail. Although, standing next to it at idle it smells rich. I replaced the accelerator pump which helped slightly but it still has a slight flat spot.
The carb is a Q-jet 7040511 which is mounted to an adaptor plate so, I assume this is not the stock carb.
Timing advanced seems to help but then it gets difficult to start when hot. I'm wondering if the advance mech in the dist might be stuck.
Any suggestions?
Coyote #1103995 05/21/2015 7:44 PM
Carburetion specialist
7040511 - California smog emissions (LEAN) Chevrolet 350.
Spread-bore to square-bore adapters are for snake-oil salesmen ;), not for engines.
Jon.
The Carburetor Shop
Coyote #1103998 05/21/2015 8:03 PM
Thats what I was afraid of.
Another previous owner hack!!!
Coyote #1103999 05/21/2015 8:04 PM
Jon, What carb belongs on this 366?
Coyote #1104011 05/21/2015 9:18 PM
The Carburetor Shop
Coyote #1104080 05/22/2015 3:17 AM
Thanks Jon.
Based on your sig I'll be "I'll be walking in the spouse's shoes" and modifying the wrong carb.
I think I just need more accelerator pump. I have the rod in the max throw position now so, I may just have to live with it.
Coyote #1104100 05/22/2015 6:02 AM
It's easy to test the distributor advance...hook a timing light up to #1 plug wire, rev up the engine and see if the timing mark moves.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Coyote #1104162 05/22/2015 5:07 PM
The vacuum advance hose may not even be connected to the correct place. And, this thing has an HEI dist. Was the HEI around in 1970?
I hope I can find my timing light. It's been a while since I needed to use it.
Between the mice and rats chewing wires and all the hacks from previous owners it may take a while to get it running right.
Nothing like having a big rat run across your foot while checking that flat spot off idle.
Coyote #1104195 05/22/2015 8:32 PM
HEI came out in 1975
366 wouldn't have had a vacuum advance, only mechanical.
BC
1960 C60 pasture art
Coyote #1104228 05/23/2015 12:54 AM
Since you have a HEI in the truck, keep it in place.
One thing to check is for bent metering rods.
http://quadrajetparts.com/q3622-power-piston-retaining-bus-t-29.html
Fred
52 3600
69 C-10
Coyote #1104286 05/23/2015 4:34 AM
Metering rods and retaining piece looked good.
I believe its a matter of not having the correct carb. Too much vacuum drop and not enough fuel just off idle. Otherwise, it runs rich since I tried to compensate.
I can live with it since it's not too bad now. In the meantime I'm searching for the correct Holley carb.
Coyote #1107953 06/13/2015 12:50 AM
Thanks to Sim for sending me the correct Holley carb for the 366. I should have it installed this weekend and see how she runs.
