| | | Forums66 Topics128,035 Posts1,055,441 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | I've got two HO72s. One is in my '56 3600 and is stock. The other is out of a 71 van and is stock. The specs are below:
1956-open differential, 4.57 gears 1971-detroit, 4.10 gears
My question is what is the best way for me to make a 4.10 open differential third member with these parts? I see it a few different ways but am not sure about the compatibility of some parts. For instance will the spline count of the shafts be the same? I want to keep my 1956 housing, shafts, and outers since I just added all new brake components and bearings.
-Pull the 4.10 gears out of the '71 axle and swap them into the 1956 open carrier and third member. -Put the '71 third member into '56 housing and pull the Detroit/replace with open carrier.
I am not incredibly familiar with these axles. How difficult is it to set the bearing preload and gear backlash on these axles if I pull them apart?
I guess the easiest thing to do would be to swap the entire '71 third member in with Detroit and all (assuming the shafts are the same spline count). If I hate the Detroit I can then start creating a Frankenstein's monster with the two axles.
Thanks for any and all advise. | | | | | Joined: May 2013 Posts: 27 New Guy | | New Guy Joined: May 2013 Posts: 27 | Thanks. That did answer my question about the interchangeability of the parts (axle spline count being the same).
Another questions: Is a Detroit locker in these trucks going to be a bad idea? It is a 2wd 3600 which will see no offroad time no I know a locker is not needed. But to save me from swapping over gear sets and setting up the third members can I run the Detroit locker in the chevy with no ill effects. How terrible do ya'll think it will be on the streets?
Thanks.
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I'm not an expert but I think the Detroit locker will allow you to turn on hard surfaces without skidding the tires. I have one in my '57 one ton and I can't tell the difference.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
