2 members (36High, Wally / Montana), 212 guests, and 5 robots.
Topics128,078
Posts1,056,052
Members48,433
#1097409 04/14/2015 6:50 PM
i found out you cannot put a
dual master on a 1954 chevy 1/2
ton with a hydramatic
not enough room
cpp bracket is to big
so had to send it back
have to use oringial mc
Thanks for the report.
anyone been able to use a dual mc
with the hydra trans
any help would be good
thanks keith
MFW Offline
Thanks for that tip. I was planning on swapping out my master cylinder on my 1954 Hydra-Matic this summer. Were you able to find any answers? Or did you just go back to the original? Where about in MI are you from?
Matt
1950 GMC 100
1954 GMC 470
1954 Chevy 3100 Hydramatic
More pix on Flickr
1957 Ford 850 Tractor (video)
i am in lincoln park
have not find out anything
MFW Offline
OK, cool. I am from Pinckney.
1950 GMC 100
1954 GMC 470
More pix on Flickr
we camp at bruin lake alot
i would like to see your truck
when we are at the camp ground
we are there in july 17-25 this
summer,i camp when they have the
swap meet in chelsea
I
I Offline
Hey guys,
Also in Pinckney. I am just getting into old trucks and am getting my shop in order.
I purchased a 51 GMC 3/4 ton with a stake bed on it. Would love to see your trucks some time.
thanks
Tom
I have been looking at installing a dual master on my 49 ad and read about several people with clearance issues so I looked a little more and found that a '64 '65 cadillac master is 1" bore and the outlets are on the other side. (frame side) 1/2 x 20. I also believe it has residual valves. Anyone else ever used this unit? Can anyone confirm it has residule valves? Kiethfielder, maybe this would give you enough room.
1949 3100
thanks keith
Keith,i'm not sure if the problem is the servo booster to trans clearance.
Would a non servo assisted one work?
I found this on eBay and wondered if might help?
Admittedly it's non servo but it would still be an improvement over the stock one.
Just a thought.
Master cylinder.
More pix on Flickr.
that was the same one i tryed
no room between hydramatic trans
and the mount for the master cyl.
to bolt to
how much clearance do you need?
is the the MC body that is hitting the trans or the outlet piping?
These folks are usually friendly enough in answering questions even though they are a wholesaler. If not then the company they list will.
If you have your clearance dimensions and needs identified they can tell you if a solution exists.
http://www.mbmbrakeboosters.com/ind...6&option=com_virtuemart&Itemid=6
Baking in the nice desert sun, breathing life back into a 48 3800 5 window.
